Kubota BX24 Safety switches
   / Kubota BX24 Safety switches #1
GregWittman
Lakewood, Wa
BX24
Does anyone know if cleaning a PTO safety switch with an electrical spray cleaner will be effective. It appears, through troubleshooting, that the safety switch is malfunctioning due to dirt or an internal failure. What are the thoughts on electrical contact spray cleaners? Or, should we just change out the squat switch? Don't want to dig into it if I don't have to.
   / Kubota BX24 Safety switches #2
I can't answer your question about the spray cleaner, but when my pto safety switch seemed intermittent, it turned out that the switch was adjusted just on the hairy edge. It is easily adjusted from under the left fender... maybe have to take the wheel off for better access. Just loosen the 2 screw & slide the switch over a bit.
Pete
Thanks Pete! I will give it a try.
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2007 STERLING L9500 MIXER TRUCK (A50854)
2007 STERLING...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
2012 Chevrolet Equinox LT SUV (A50324)
2012 Chevrolet...
IH Cub Lo-Boy 154 (A50514)
IH Cub Lo-Boy 154...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
