kubota bx24 HYD system
   / kubota bx24 HYD system #1
tfehn
Louisville Ohio
Kubota BX24
I Have a bx24! Followed artisans build on grappleomatic. He has a bx25! Looking to get the same fasse valve. I talked to him and he didn't know if his hyd system was the same as mine.He suggested I start a thread here to find out. All help would be much appreciated !!! As soon as I get valve I will start a thread with all pics. So here is the question.
Are both of these Hyd systems open center systems or closed center systems?
   / kubota bx24 HYD system #2
i don't know what you have without looking. Open center systems the hyd. pump is usual attached to be constantly driven i.e. off the engine, coupled to the harmonic balancer on the front of the crankshaft. That said, Case has/had on demand pump, closed center system. Who else? Donno. Cat typically others are open center, pump circulates fluid constantly from resevior to pump inlet back to resevior. Cheaper to build. adjustments are fairly critical on closed center. Rv's have on demand water systems. When you open a fasuet the pump comes on.
2020 INTERNATIONAL LONESTAR TANDEM AXLE SLEEPER (A51222)
2020 INTERNATIONAL...
4 1/2 150G DRILL STEM 288 JOINTS (A50854)
4 1/2 150G DRILL...
2025 8ft Office Shipping Container (A49346)
2025 8ft Office...
2011 CAT 430E BACKHOE LOADER (A50854)
2011 CAT 430E...
2013 GMC Sierra 2500HD Ext. Cab Pickup Truck (A49461)
2013 GMC Sierra...
2024 CATERPILLAR 299D3 XE SKID STEER (A51242)
2024 CATERPILLAR...
