kubota bx24 2009
   / kubota bx24 2009 #1
dennynep
Hi I was 3 degrees last night i let it warm up a bit then started the machine while letting it warm up all the sudden the was a lot of hydraulic oil The filter blow open. so my question is was there water in the system and the only place i can see to let moisture in is on the back hoe ram should i be spraying the rams so the seals don't dry out? And if so how do i remove all the moisture? thanks
   / kubota bx24 2009 #2
When was the last time you change hyd. and filter?
Older B6100 had same problem.
   / kubota bx24 2009 #3
What kind of fluid are you running? Kubota makes a Super UDT fluid that might flow a little better. When it’s really cold hydraulic fluid gets thick and that could have been the problem.
   / kubota bx24 2009
Hey Thomas about 300 hours / 5 years Hi Dave i do believe it was some less expensive oil now i have the super udt in it. I removed the oil plug and moved the pistons on the backhoe and front bucket and steering wheel to try and remove all the fluid. I guess i'll have to see what happens.
2019 CATERPILLAR 299D2 SKID STEER (A51242)
2019 CATERPILLAR...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2013 JOHN DEERE 470G LC EXCAVATOR (A51242)
2013 JOHN DEERE...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
Unused Delta Crash...
