Kubota BX2360 keeps blowing ACC fuse
   / Kubota BX2360 keeps blowing ACC fuse #1
Laps
Blountville, TN
Kubota BX2360
My 5 year old Kubota now keeps blowing the ACC fuse as soon as the ignition switch is engaged. When that happens the gauges don't work nor the lights nor the hour/rpm meter. I have looked for obvious shorts or pinched wires and can't find any.
Checked the battery connections also.
Any suggestions?
   / Kubota BX2360 keeps blowing ACC fuse #2
What is running off your account circuit?
   / Kubota BX2360 keeps blowing ACC fuse #3
ACC circuit, stupid autocorrect.
I don't have any accessories hooked up, no accessory lights etc. As soon as I turn the ignition switch to start the motor the ACC fuse blows. So that leaves me with no dash gauge readouts, no lights, no meter/hour readout. The tractor still runs normally though.
   / Kubota BX2360 keeps blowing ACC fuse #5
Exactly what position does the ignition switch have to be in in order for the fuse to blow? RUN, START, or PREHEAT?
It will blow as soon as the switch is turned to the first position, which is the preheat. The preheat indicator light DOES come on, indicated on the dash, but that is the only indicator that still works on the dash.
   / Kubota BX2360 keeps blowing ACC fuse #7
I would start following wires, you may have one that has rubbed through and grounding out. Also try unplugging anything that does not work once the fuse blows. If the fuse no longer blows after you unplug something, you have found your problem.
Correction to my post: the first position is RUN, and it blows at that position. The next position is Preheat, and the third position is start. Sorry for the confusion. Thanks.
Thanks, I'll do that. I wonder if it could be the ignition switch it self?
   / Kubota BX2360 keeps blowing ACC fuse #10
Not likely, as it just passes current through it. If that were the case, it'd blow the fuse supplying the switch.
TOYOTA 8FGCU30 FORKLIFT (A50854)
TOYOTA 8FGCU30...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2020 INTERNATIONAL LT625 SLEEPER (A50854)
2020 INTERNATIONAL...
2019 INTERNATIONAL 4300 CDL REQUIRED BOX TRUCK (A51222)
2019 INTERNATIONAL...
SDLG WHEEL LOADER FORKS MAST W/ 48" FORKS (A51242)
SDLG WHEEL LOADER...
