kubota bx2350
   / kubota bx2350 #1
maltyson
uk
bx2350
Hi I'm new to this forum and wondered if anyone has a BX2350 with a backhoe and if so is it attached solely by the 3 point or does it have a frame that attaches to the tractor? also are they worth getting?
Thanks in anticipation of a reply.
   / kubota bx2350 #2
Hi. Welcome. I do not have the BH attachment but I think most you remove the 3pth to install the backhoe. Would love to have one for my BX2200.
   / kubota bx2350 #3
H and welcome to the forum! :welcome:
I'm going to move your thread over to the Kubota section. I'm betting that someone over there can answer your question. :)
   / kubota bx2350 #4
Woods makes them for BX tractors. It's my understanding they come with a subframe.
   / kubota bx2350 #5
The BX24 is the TLB version of the BX2350. The BX24 has a frame mounted BH so you might also want to investigate how that's done. For my usage, the front loader is used all the time while my BH sits in the barn for occasional use. Just depends on what you have planned for the 2350. If you plan on moving a lot of dirt, maybe a rental excavator would be less costly in the long run.
SCAN FOR HAULING AND FINANCING INFORMATION (A51248)
SCAN FOR HAULING...
2008 Sterling Bullet Utility Truck, VIN # 3F6WK76A88G352277 (A51572)
2008 Sterling...
2018 HAMM H7 SMOOTH DRUM ROLLER (A51246)
2018 HAMM H7...
2008 IC Corporation PB205 Bus, VIN # 4DRBVAANX8A506494 (A51572)
2008 IC...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2018 CASE IH 110N LOT NUMBER 223 (A53084)
2018 CASE IH 110N...
