Kubota BX2350 stutters after low gas
   / Kubota BX2350 stutters after low gas #1
mlewellen
I ran my BX2350 low on diesel and it hasn't run correctly since. We have replaced the fuel filter, bled the lines but it still stutters when a load is put on it. Just driving around it seems to run fine, but when I put the mower deck down or drive up hill it starts to shimmy and shake and wants to die even at full throttle.
What else can I do before having to take it to the shop?
Any ideas?
M
   / Kubota BX2350 stutters after low gas #2
You know there are two fuel filters on the bx's. You might want to change the other one also.
   / Kubota BX2350 stutters after low gas #3
Most likely you need to bleed the system again to get that last little bit of air out of the system.Could have a fuel line restriction or could be sucking air. Try to blow back the lie into the tank and check both filters. This sounds like a fuel supply problem but most likely still air in the lines..
   / Kubota BX2350 stutters after low gas #4
I think your problem started with the "low gas". Just kidding. I've had the same issue with my B. Rebleed.
   / Kubota BX2350 stutters after low gas #5
Check both filters again, you may have broken some gunk loose from the bottom of the tank when it ran low.
2008 Wells Cargo T/A Enclosed CERT Trailer (A50324)
2008 Wells Cargo...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
P.T 1000 Gallon Supply Tank (A50120)
P.T 1000 Gallon...
2013 Nissan Pathfinder SV SUV (A50324)
2013 Nissan...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A50322)
2018 Toro Z-Master...
2014 Kia Optima Hybrid Sedan (A50324)
2014 Kia Optima...
