Kubota BX2350 pedal sticking forward and reverse
   / Kubota BX2350 pedal sticking forward and reverse #1
Tony891
Oregon,Ohio
BX2660
I know there has been some discussion but is there a real fix to stop the sticking forward and reverse pedal on this model tractor? I am aware of the spring adjustment. Didn't work. It is lubricated at all points. I haven't tried using the super HDT fluid yet. The condition is worse in the cold and pulling under a heavy load. Thanks
   / Kubota BX2350 pedal sticking forward and reverse #2
what grease did you use for the hst pedal when greasing the pivot under floorboard? I always use lighter duty grease, this way its less thick and moves better in the cold. I remember after 2-3 years of using the BX, I took the floor board off the tractor to gain access to the pivot shaft and slide it out part way so I could clean up the shaft with degreaser and put it all back together and regrease it and its back to normal. Its starting to be "sticky" again so its time to do it again soon. Problem is that it is not a fast job, lots of parts to take off just to gain access again and I'm actually dreading it since the first time I was curious and it was no problem disassemble and reassemble, the time is a factor and its a all day job. I might attempt to do it from under the tractor this time.
2007 Astec RT-360 Ride-On Trencher Backhoe (A50322)
2007 Astec RT-360...
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
2012 Hyundai Elantra Sedan (A50324)
2012 Hyundai...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2018 FREIGHTLINER...
New Wolverine Skid Steer Hydraulic Breaker (A53002)
New Wolverine Skid...
Kubota ZG327 (A50120)
