well i have removed the rear plastics and seat etc so i can look at the levers properly.the lever seasm to be bolted with 2 bolts , same as high low , its bolted at a slight different angle to the bit fastened to the transmission shaft , which i think is correct.,i can move the lever fine its seems to go into 4 wheel drive ok,it does not catch on any thing(i cannt see a bend anyware causing a problem), unless i am missing something , i jacked all wheels of the ground put in to high box ,4 wheel drive , i could turn wheels at back to confirm it whas moving front wheel , but only with diff lock pressed otherwise both rears turned opposite to each ther ( i think this is the action of the diff) only when diff lock pressed did the front turn.it was hard to turn but it turn slowly in 4x4 and did not jump out.May be as it was only very slowly turning.
