Kubota BX232 - Major leak after adding a gallon of hydraulic fluid
/ Kubota BX232 - Major leak after adding a gallon of hydraulic fluid
For future reference for myself and any readers in this stituation - of the two pictures I posted, where exactly would you have put adhesive?
For example on the picture where the seal and bearing are exposed, would you have put a thin layer of adhesive acting like chalk around the
rubber edge before you push the metal cover end piece or do you put enough one where it glues both the rubber and metal piece?
I ask because of the metal cap piece is glued, it would seem to create a problem. My guess is around the rubber seal where it meets the metal but
thought others may want clarification as well. Thanks for the tip on checking the fluid when machine has been running for a bit.
/ Kubota BX232 - Major leak after adding a gallon of hydraulic fluid #62
Any adhesive would need to be applied to the metal flange of the seal were it meets the outer end of the rear end axle housing, I certainly would not use locktite to bond it most of those products would secure it to well. All you need to do is keep the seal from popping out again, also that is a simple repair if you make it to hard to remove and overfill again and over pressure the housing where will it release the next time? a harder point to repair.
/ Kubota BX232 - Major leak after adding a gallon of hydraulic fluid #63
Just for reference, I always take a strip of emory cloth and clean up the axle shaft before messing with the seal. Any dirt or grime or burrs can nick the seal and make it leak a little. Yours didn't look to bad, maybe just rusty.
/ Kubota BX232 - Major leak after adding a gallon of hydraulic fluid #64
Thanks for taking the time to update.
/ Kubota BX232 - Major leak after adding a gallon of hydraulic fluid #65
I applied adhesive sealant where the metal cap end piece meets the axle housing, Then push home. There appears to be nothing to hold this seal in if to much pressure.
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
2018 International DuraStar 4300 2,000 Gallon Water Truck (A59230)
2018 International...
FARMHAND 827 FEED MILL (A60430)
FARMHAND 827 FEED...
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
UNUSED FUTURE FT20-1 EXCAVATOR (A60430)
UNUSED FUTURE...
UNUSED IRANCH MINI EXCAVATOR QUICK COUPLER (A60432)
UNUSED IRANCH MINI...
