Kubota BX232 - Major leak after adding a gallon of hydraulic fluid
   / Kubota BX232 - Major leak after adding a gallon of hydraulic fluid #1
Tractor_Jim_CT
Connecticut
BX23
Sorry - I posted in the wrong area and do not know how to delete this thread. I moved this to Kubota Owning Operating. Hi everyone. I am lost and not sure what to do. About a month ago my FEL center hydraulic cylinder was leaking and with the help from the TractorByNet group, I removed the cylinder, had it repaired and re-installed it. The tractor was bh and FEL worked well but seemed slower than normal. I stopped by my dealer and inquired about which Kubota hydraulic fluid they used when they serviced my BX23 recenty and I bought a gallon. I figured with the past leaking cylinder issue I most likely lost fluid so when I checked today I noticed the stick was dry. I added about a gallon and the tractor seemed to be running well, except I started seeing fluid on the ground in areas were I had been. I looked under the tractor and there was a steady flow of hydraulic fluid sreaming down on the rear left side of the tractor based on the left side if I was sitting in my seat. I lift the seat and crawled underneath and I can not tell where this fluid is coming from. I can hear a draining sound and not sure if anyone has had something like this has happen to anyone else. I added a picture to give members an idea of what I am seeing. The FEL and BH still works.
   / Kubota BX232 - Major leak after adding a gallon of hydraulic fluid #2
When you added "about a gallon", did that bring your fluid level up to the correct spot on your dip stick?
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2019 KOMATSU WA320-8 WHEEL LOADER (A51246)
2019 KOMATSU...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
