smittyjones
Hey all, I have a BX2230, it runs great in every way, but it won't shut off. When I turn the key, gauges go to zero, but it keeps running. This all started when I'm a dummy and accidentally shorted the aux power wires under the seat.
Solenoid fuse is good, swapped it with the extra to check even. Timer relay is good (neighbor has the exact same tractor, so I switched with his to check), still doesn't shut off. If I apply power to the shutoff solenoid, it shuts off.
It also doesn't shut off when I stand up in gear or with the PTO running, when it should. I checked the seat sensors and they were good.
Any advice?
Any advice?
