Kubota BX22 Steering Problem
   / Kubota BX22 Steering Problem #1
hdfxrs
The steering on my 2000 Kubota BX 22 is not responding properly. Gentle turns of the steering wheel do not turn the tractor. I have to apply a quick motion to the wheel to get it to respond. This makes adequate control difficult. Any ideas on what could be causing the problem. The hydraulic fluid level and quality is fine. Filter is new.
   / Kubota BX22 Steering Problem #2
I will be interested in what kind of replies you get as I own one also. How many hours on your machine ? I have about 500 on mine and steering is fine so far. Is it new to you or used.
   / Kubota BX22 Steering Problem #3
Check with your dealer, I believe they had a problem with the steering valve and there was a notice sent out.... not sure. I believe it was somewhat of a common problem for awhile.
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
2018 KENWORTH T680 SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2014 Freightliner M2 106 Ambulance (A50323)
2014 Freightliner...
10ft x 8ft Container with Side Door (A51573)
10ft x 8ft...
