Kubota BX22 Fuel Bleeding?
   / Kubota BX22 Fuel Bleeding? #1
joebob1
santa rosa CA
kubota BX22
Hi first time posting here, its such a wealth of knowledge being able to go back through the forums and ask questions. :)
I have a BX22 that I replaced both fuel filters and I dont see fuel filling the filter in the engine compartment the one down below is full. The motor will start up and run but I think I might of let it run to long waiting for fuel to move, it sputtered once and I turned it off. I checked the fuses and I here the fuel pump when the key is turned on "if I get under the bx and close to the pump". I'm not sure if the pump is working correctly or is there something that I'm missing? I am really thankful for you replies
   / Kubota BX22 Fuel Bleeding? #2
Turn the key and start the engine and let the engine run. The BX has an electric fuel pump, no need to bleed the fuel. Just let it run you will be OK.
Oh yea welcome to TBN.
Thanks for the response. I got it, I had a blocked lifter pump and I was expecting to see fuel when the pump turned on not 1 hour later lol, anyhow had her up and working hard to day with no problems thanks again Tom:)
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
Golf Cart (A51694)
Golf Cart (A51694)
Toro Zero Turn (A50324)
Toro Zero Turn...
NEW HOLLAND TN75 TRACTOR (A51247)
NEW HOLLAND TN75...
40' CONTAINER (A51248)
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
