Kubota BX22 electrical issue
   / Kubota BX22 electrical issue #1
fussbudget
Kubota BX22
Hello everyone, I thought I would join this forum to post a question/problem I am having with my BX22. It's about 5 years old. While sitting idle (not running) my wife discovered that the yellow signal lights were flashing. She tried to turn off any switches but nothing worked. After giving up trying to stop the flashing lights she just let the bx22 flash until the battery died.
I came home and removed the battery, charged it to 75% and re-installed the battery. I unplugged all of the wires going to the rocker switches on the face panel. The BX22 started normally. However now when I turn it off, I now have the left rear signal light and warning light full on. The left head light has a glow coming from it. The only fuse that seems to take care of extinguishing the lights is the one marked H/LP. Not sure what this does. I also noticed that the fuel gage no longer works.
Any ideas or should I just go for a service call?
   / Kubota BX22 electrical issue #2
Hi This sounds a little different from bx23 water in switches which causes lights 2 flash so not alot of help. Dry switches and use dielectric grease or thread somewhere for direct replacement marine (waterproof) switches. Need 2 do myself. Seat rubbed wire raw????
   / Kubota BX22 electrical issue #3
It is the cheap switches. You can take them out and take them apart and maybe fix them I just unplugged them all. They are not water proof and water gets in them all. If you just gotta you can buy new ones.
I simply have no use for flashers turn signals or even lights for that matter.
   / Kubota BX22 electrical issue #4
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
43013 (A51691)
43013 (A51691)
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A52748)
2023 NEW HOLLAND...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
