Kubota BX1860 Will Not Start
   / Kubota BX1860 Will Not Start #1
PHudson68
Kubota BX1860
I have a Kubota BX1860 that will not start nor are there any signs of combustion.
I have performed the following to the fuel system:
  • Removed fuel tank and cleaned out the garbage left by the decaying fuel level unit. (A considerable amount of rust was present). Reinstalled tank
  • Replaced all fuel supply lines from fuel tank to fuel injector pump
  • Replaced (2) inline fuel filters
  • Replaced electric fuel lift pump
  • Fresh diesel fuel
  • Bled air at injector pump body inlet
  • Bled air at injector nozzle inlets, one at a time
The starter turns over the engine normally but there are no indications of combustion.
The glow plug indicator light illuminates.
There is no sign of fuel oil or coolant in the motor oil.
The engine stop solenoid is pulling in and out but I’m a little unclear to it’s sequence of operation. This machine incorporates a Operator Presence Control amid a Timer Relay.
One of my first questions is: What is the normal lever position on fuel the valve connected to the solenoid? Power to the solenoid retracts the plunger, does this cut fuel or open?
Second question: What am I missing?
Prior operation was standard except for having to occasionally blow fuel line back into tank to clear. The machine was shut down normally without any indication of malfunction. I have worked 1800 hours on this machine and maintained as required. Other than a tremendous amount of broken plastic body pieces, there are no abnormal disturbing signs of wear, leaks, or smoke.
Any and all advice is welcomed and greatly appreciate.
   / Kubota BX1860 Will Not Start #2
If you have not done so clean or replace the air filter and ensure the path to the intake manifold is clear. Sometimes it is also possible to get a defective fuel filter.
   / Kubota BX1860 Will Not Start #3
Your BX1860 is several generations newer than anything I have, but I think this still applies. The fuel valve rod would be extended when in the run position and retracted to kill the engine. It is on a timer and and will retract when the switch is turned off and then return the run position after several seconds. You shouldn't have to bleed the fuel system. It self bleeds but no harm doing that. Do you have fuel at the injector when cranking?
This fuel system sounds like what is on my ZD and not on my older BX, as you cannot see the solenoid operation on it.
   / Kubota BX1860 Will Not Start #4
Are you sure the lift pump is working? Have you checked all fuses?
   / Kubota BX1860 Will Not Start #5
It might be considerate to summarize the 14 replies you got to the identical question posted on the other forum…would save everybody from telling you the same thing a second time, and perhaps get you some different suggestions, rather than just a repeat a second time of what has already been offered.
   / Kubota BX1860 Will Not Start #6
Check seat switch
SUCKER RODS (A48992)
2008 Hyundai Tiburon Coupe (A48082)
2008 Hyundai...
2009 Ford Ranger Pickup Truck (A48081)
2009 Ford Ranger...
2019 KENWORTH T880(INOPERABLE) (A48992)
2019 KENWORTH...
2022 Club Car...
Set of 4 Tires (A49346)
Set of 4 Tires...
