Kubota BX1800 hydrolic leak
   / Kubota BX1800 hydrolic leak #1
Patsfan35
have a kubota BX1800. I have a hydrolic leak in one of the hoses that is underneath the tractor that runs to the hydrostatic transmission. It is blocked so I cannot see how it is connected. I really need the manual or a picture of it. Does anyone have a copy of the BX1800 manual. If someone can tell me how to fix this that would be great also. Thanks.
   / Kubota BX1800 hydrolic leak #2
I have a BX2200, which should be pretty much the same as far as layout goes. There shouldn't be any hoses, unless you are talking about the hydraulic suction line that runs from the bottom of the transaxle by the back, left tire up along the left side of the pto shaft and then to the top of the transaxle. I think that all of the hydraulics are steel lines unless someone replaced a steel line with a hose. If you can give a better discription or a picture it might help.
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2013 Volvo Semi Truck (NOT RUNNING)(TITLE) (A50774)
2013 Volvo Semi...
2022 John Deere 6135E (A50120)
2022 John Deere...
2015 Kenworth T400 T/A Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
City of Tampa (1202) Year: 2016 Make:CRAE VIN:1H9AADAD9G1674168 (A51692)
City of Tampa...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
