Kubota BX1500 Hydraulic Angle
   / Kubota BX1500 Hydraulic Angle #1
blackmajicwoman
Westport, MA
Kubota BX1500, ZD331
I recently purchased and installed the quick hitch and TG2754 plow to my BX1500. Much to my dismay, the manual angle control requires me to get off the tractor seat to change the angle. I use the plow strickly for snow. Does anyone have any ideas on mounting a ram to control the angle. Much appreciated. Thanks.
   / Kubota BX1500 Hydraulic Angle #2
I had the same problem.
You will need an extra hydraulic outlet, an 8" hydraulic ram, a couple pieces of 4 X 8 X 1/4" metal and a welder.
I tack everything together to get the correct geometry and then weld everything together.
I have not had much run time to determine durability, but so far it seems to work well.
I can post a picture if desired.
JD4600 with 460FEL with pallet fork and 7'6" Western Snow Plow, JD LX279, 84" KK finishing mower, 84" KK Landscape Box, 84" KK Landscape Rake, 84" KK Blade, and 72" KK Bush Hog, 7' Northern Tool Backhoe, Bri Mar 6X10 Dump Trailer, 20' Rugged Road Equipment Trailer.
Greg
Thanks for replying. Yes, please post a pic. I already ordered all of the parts I need, which include a 2"x8" cyclinder and all of the connectors and hoses to hook up to my existing FEL valve (of which only two of the four ports are being used by the up/down cylinder for the plow). I am an OK weldor an hopefully will make it all work. Thanks.
Shaun
   / Kubota BX1500 Hydraulic Angle #4
Here is the picture.
Greg
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
ATLAS XAS110 COMPRESSOR (A52472)
ATLAS XAS110...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2001 Blaw-Knox PF 150 Paving Machine (A52384)
2001 Blaw-Knox PF...
FAKE (A52472)
FAKE (A52472)
