Kubota BX Post Hole Digger
   / Kubota BX Post Hole Digger #1
EverythingAttachments
Elite Member
Newton NC
Which One do you want to know about?
Has anyone had a problem with the toplink end of their Land Pride post hole digger boom bottoming out on the BX toplink bracket assembly?
Notice how close it is in the picture(inside the red box). The lift is partially lowered because the auger is in the ground.....
   / Kubota BX Post Hole Digger #2
Don't have a land pride but I have that problem with my TSC PHD on my BX.
Thanks for the input sea2summit. It seems either not many people have this Land Pride PHD or no one wants to talk about it.
Notice how the tractor is hooked up to the outer lift arm pins, but the design looks as if it should have inner lift arm pins.
BUT.....if it had inner lift pins, which makes more sense, then the tractor's lift arms would be closer together and the lift height would increase.....this means the issue with the top link bracket would be amplified.
Travis
2020 JOHN DEERE 3032E TRACTOR LOADER BACKHOE (A51243)
2020 JOHN DEERE...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2006 CATERPILLAR D604S GENERATOR (A50854)
2006 CATERPILLAR...
71058 (A49346)
71058 (A49346)
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
Quick Attach 6' Snow Blade (A50515)
Quick Attach 6'...
