Kubota BX 2230 motor 4WD with PTO/lift/hyd deck lift
   / Kubota BX 2230 motor 4WD with PTO/lift/hyd deck lift #1
johneking
Hot Springs, AR.
Kubota B-20
WELL -- here's my problem:
My church bought this tractor YEARS ago as some ground is soft and it had fairly good maintenance while the older gentleman was taking care of the ground.
When he got too feeble, others tried to mow etc. with it and other than the deck {concrete curb stops, curbing etc. were hard on it!} it was in decent shape.
One member "rebuilt" the motor several years ago and it ran great ever since -- then developed a knocking sound.
Our youth pastor at the time said his research showed it could be an injector and bought three new injectors -- then he lost his position and moved.
As the senior pastor at the time is a relative and I have fixed just about everything he owns {weed eaters, blowers, chain saws, riding mowers etc.} he asked me to see if I could fix it.
SO -- I bring it to my shop, listen to the "knocking sound" and think -- injector?!
I replaced the 3 injectors -- knocking sound still there -- imagine that!
Ran out of time to do more trouble shooting and as the church had bought a new Z-Turn there wasn't a need to hurry so I moved it out of the shop {needing the room} and as I was driving it around to the side -- BANG/OIL! -- I'm thinking a broken rod through the block on right front!
Looking for a motor -- $4K to $6K!
With its age, condition {I had repaired the deck etc.} I was seeing a value of $4500+ with it running -- now I'm guessing $1300!
Anyone interested in either rebuilding/replacing/buying the whole tractor? I just don't seem to be able to find the time at 72 and "retired" {? :)} and still running a storage business, Bush Hog business and a small flying business -- oh, and I have two daughters who "call dad -- he can fix it" {they even had a T-shirt made for me with a big screw on it -- "IF DAD CAN'T FIX IT, WE'RE ALL SCREWED!"
I'm open for suggestions,
John
   / Kubota BX 2230 motor 4WD with PTO/lift/hyd deck lift #2
It’s probably not worth fixing. I’d get whatever you can for it.
Thanks, Dave, for your reply.
I'm thinking I'll start taking it apart to find out what happened -- then decide.
I have never welded a hole in a block, maybe it's time.
   / Kubota BX 2230 motor 4WD with PTO/lift/hyd deck lift #4
Worth more in parts. Sell locally & on eBay. Quite a good market for JD & Kubota parts.
   / Kubota BX 2230 motor 4WD with PTO/lift/hyd deck lift #5
I attended a church at the request of my fiancee' where they raised 12000 bucks for the down on a new piano. The baby grand was just not enough for the music minister.
Point is that this issue could be brought up to the congregation. Maybe someone could donate a better mower or cash could be raised during church.
   / Kubota BX 2230 motor 4WD with PTO/lift/hyd deck lift #6
If the block is windowed I can’t imagine it’s worth messing with the engine. If you got a cheap used engine it might be worth fixing if you had free time.
Deluxe Hitch Plate (A49339)
Deluxe Hitch Plate...
Landini Vision 105 4WD Tractor (A49251)
Landini Vision 105...
2015 Chevy 1500 four-door, 4 x 4, 210,644 miles, (A47371)
2015 Chevy 1500...
30ft Belt Elevator (A49251)
30ft Belt Elevator...
Bulldog 2 5/16 in. Hitch Coupler (A49251)
Bulldog 2 5/16 in...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
