Kubota BX 2230 Hydraulic Kit
   / Kubota BX 2230 Hydraulic Kit #1
robertbakerie
Ireland
BX 2230
Hi,
I've a BX 2230 and I'm looking to add a rear hydraulic kit. Has anyone ever done this for this model? What kit number did you use? Was it expensive?
Thanks for any help on this.
Robert.
Update!
Hi,
I installed the rear hydraulics on my Kubota BX 2230D.
The kits needed were the BX 7322 and BX 7324 and I bought these from
Messicks (http://www.messicks.com).
Dealt with a Loren Klingaman who was very helpful.
BX 7322 ($295) and BX 7324 ($181) (This second kit is a hose kit and is for a tractor without a loader.)
The kits contain good photo instructions which are easy to follow, but on my tractor, did not anticipate attached plates over the right hand side oil return valve. This looked bad at first, but was an easy problem to deal with.
I carefully documented my steps with photographs and these are available here
http://picasaweb.google.com/Waterpolo.Ireland/KubotaBX2230Hydraulics#
Hope this helps the next person.
Robert.
   / Kubota BX 2230 Hydraulic Kit #4
Robert, thanks for sharing that. It will help some one out. Hows things over in Ireland these days?
2010 KMC 3376 Peanut Combine (A53472)
2010 KMC 3376...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2003 Polaris Sportsman 700 Twin (A51573)
2003 Polaris...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2019 HINO 268 26FT BOX TRUCK (A52576)
2019 HINO 268 26FT...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
