Buying Advice Kubota Bucket
   / Kubota Bucket #1
Tcant
Kubota B3200
I have a B3200 with a"light duty" straight (no quick attach) bucket. Will a LA243A slide on as a replacement?
   / Kubota Bucket
Correction on my post - it should read B3200!!
   / Kubota Bucket #3
Not sure what you're asking. An LA243A is a loader, not a bucket. What do you mean "slide on as a replacement"?
   / Kubota Bucket
I saw an ad with a picture of what looked like a new Kubota Orange loader bucket with a printed ID attached LA243A. Since my B3200 bucket is identified as light duty I wanted to know if I could replace it with the advertised bucket. Would it fit?
   / Kubota Bucket #5
According to my 5 minutes of research, you have LA504 Loader. Two different buckets were offered on that loader from what I understand. One is a 'light duty' 60 inch bucket and one is a 54 inch bucket.
I see no reason why you can't put the appropriate 54 inch bucket on your loader. As a suggestion, you might also want to put a 'cutting edge' on your bucket. It will add some strength.
You might also want to consider the Quick Attach if you swap buckets. It's not complicated but it requires some thought and some knowledge from your dealer.
Good Luck
   / Kubota Bucket
Thanks for the reply. My LA504 measures 59" so I guess that's a 60" bucket - close enough. I'll look into the cutting edge.
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
Komatsu PC56 Excavator (A51573)
Komatsu PC56...
2013 FREIGHTLINER CASCADIA 125 DAY CAB (A52141)
2013 FREIGHTLINER...
New Holland 824 2 Row Corn Head (A50774)
New Holland 824 2...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
