Kubota Bucket Parts
   / Kubota Bucket Parts #1
GMCKIRCH
I am looking for the "ears" where the loader arms attach to the bucket. I have a pair of forks with a frame and want to mount them to a set of Kubota ears. I have the ability to weld the ears up to the forks but I do not have the ability to make a set of ears with the proper holes. Any idea where I can buy just a pair of the ears?
Thanks,
Steve
   / Kubota Bucket Parts #2
its just plate steel, Any good machine shop/welding shop should be able to make them for you.
   / Kubota Bucket Parts #3
Steve...
I'm sure you could buy them at a machine shop...
BUT, if your post included any additional information ... like: Approximately where you are located, what loader OR tractor model you have, or better yet the pin diameter and spacing for your bucket.
The reason I say this is I have a factory bucket that I removed when I switched to SS quick tatch system. I always figured I would slice the attaching points off my bucket and weld on SS attaching plates. I started to do that got the plates but never did it, If you were in the general area it would be practical to take you my bucket and let you have the original attaching point assembly... but there is no reason to consider this without knowing where you are, you could be anywhere on the planet and post to this forum... also if the pin holes are the wrong spacing or size...I only mention this because many people have asked general questions without including enough information to actually get the best response, I am sure I am not that unique there has to be hundreds of other pin attachment parts out there not being used... some could be very near you. KennyV
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
2022 KMC 5610 LOT IDENTIFIER 197 (A53084)
2022 KMC 5610 LOT...
2023 JACTO JATAO-1000 LOT IDENTIFIER 67 (A53084)
2023 JACTO...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
Super Material Lift MH1000 (A53472)
Super Material...
