kubota binding up
   / kubota binding up #1
french00
L245DT
My kubota tractor binds up while moving. Has anyone else encountered this problem.
   / kubota binding up #2
Do you have it in 4wd on hard dry surface such as concrete? If so, it will do ok when you go straight, but the front wheels need to be able to slip when you turn. That is normal for most 4wd. Same thing happens with my truck.
   / kubota binding up #3
In fact, I believe even in a straight line most 4X4 tractors lead with the front. In other words, the fronts are always pulling just a little faster than the rears.
   / kubota binding up #4
Yes, sorry to say that the front wheel had a bad bearing. The steel balls got in the gears and stopped the tractor dead. :confused:
JOHN DEERE 54D LOT NUMBER 148 (A53084)
JOHN DEERE 54D LOT...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
CFG Industrial SAII100 (A50123)
CFG Industrial...
HANG ON MAST W/ 58" FORKS (A51247)
HANG ON MAST W/...
RCcar RC-G2.0 Electric Golf Cart, NEW! (A52384)
RCcar RC-G2.0...
