sherwood00
Boom cylinder is drooping on my Kubota BH77 backhoe on a 2008 Kubota L3400 HST with 600 hours. There is no fluid leaking anywhere. I put one of those blue pills in the hydraulic reserve, but it still droops overnight. Haha...
When digging after it warms up it won't lift the arm and bucket up. I have to wait a couple of seconds and then pull back on both levers to get it up. If I turn the unit off and don't latch the backhoe the boom cylinder slowly droops down. The dipper and bucket cylinders appear to work fine and they don't droop when left extended.
I Took the rig to the Kubota dealer and they recommend replacing the Control Value and Pressure Check Value for $2360!? What the...! I'm instead bringing the rig home and plan to take the control value and pressure relief value apart, clean it, reassemble and hope that in the process I find a bad o-ring or some obvious reason for the leakage. Anyone have advice about this drooping issue beyond buying the backhoe flowers and dinner or has anyone done a control value rebuild?
