Backhoe Kubota BH 90 Backhoe question
   / Kubota BH 90 Backhoe question #1
allthingsoutdoors
Kubota L3240
I have a Kubota L3240 HST that I need a backhoe for. I was first looking at the less expensive 3 point hitch versions, but everyone strongly recommends a subframe mounted version. I have decided that is the way I need to go.
I have found a used BH 90 Kubota backhoe attachment locally. The owner already sold the tractor it was attached to and did not remove the subframe.
My Kubota dealer said I would need a BX 4997 mounting kit and a BX 4977 subframe.
He did not know if the BX 4997 mounting kit included the hydraulic fittings needed or not.
Does anyone who has purchased a BH 90 remember if the hydraulic kit needed came with the backhoe or if if was included in the BX 4997 mounting kit.
My tractor does not have the rear remotes. The BH 90 just has the 2 hoses with the male and female quick disconnects.
Any information would be appreciated.
   / Kubota BH 90 Backhoe question #2
I bought one in June, and each, and every thing needed, had its own part #, and associated expense. So to answer your Question, I would say you will have to buy every thing seperate.
   / Kubota BH 90 Backhoe question #3
I have the L4400, had to buy the sub frame mounting kit, I run off the tractor hydraulics, so I dont know about pumps, hooks up and removes simple, 1 man op
   / Kubota BH 90 Backhoe question #4
Can you get to the new owner of the tractor and buy what you need from him?
I wish I could contact the buyer of the tractor. It was sold in the spring to someone out of state and the seller of the backhoe does not have any contact info.
I would sure like to buy the subframe mount used for a few hundred bucks over paying $800 from Kubota.
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
2022 KUBOTA KX040-4 EXCAVATOR (A51242)
2022 KUBOTA...
Land Honor Quick Attach Vibratory Plate Compactor (A50514)
Land Honor Quick...
Ficklin Mod. 4500 Gravity Wagon (A50514)
Ficklin Mod. 4500...
2012 BOBCAT E80 EXCAVATOR (A51242)
2012 BOBCAT E80...
