Backhoe Kubota backhoe question
   / Kubota backhoe question #1
SCOOBY14B
Cleveland, Georgia
Kubota BX2660 Ansung B2504 FE loader and Kubota MMM
Got a question...
I'd STILL like to purchase a 4wd Kubota tractor in the future (near I hope). I'd like something in the 30-35hp range. I'd like to get a backhoe in addition to the loader if I can swing the cash. It'd be very useful, and open up additional business opportunities.
QUESTION: How do they mount? I've seen 3 point and subframe mentioned, but don't know the difference. I figure the 3 pt mounts using the the 3 pt, but read where it can increase stress on the tractor vs subframe.
How does a subframe mount?
Is there any operation differences between the two (speed, strength)?
Are they both easy to remove?
How long does it take to remove them?
Thanks in advance.
   / Kubota backhoe question #2
Most folks will tell you to stay away from 3-point hitch type - just too much stress on the tractor midsection. The physical subframe mounts along both sides of tractor essentially at the lowest point. It takes me a realistic 5 minutes to remove or reinstall my BH75.
Mike
Mike
Thanks for the info. How much $$ does it usually add? I'd like to get something equivalent to a 3430 or a 3130 (not familiar with the new model #'s).
I'm wanting a hydrostat, R4 tires, FE loader, backhoe and several rear remotes.
   / Kubota backhoe question #4
Right now I have been quoted $8000 for a BH90 backhoe installed on my L3130. This is a subframe mounted backhoe. The L3240 is the new model comparable to the L3130. Bought with the tractor, it would be somewhat less. I have been thinking about getting one with the new Kubota financing deals but will wait a while to let the financial turmoil die down before making a decision.
Vernon
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2021 Doyle 8 Ton Trailer Tender (A52748)
2021 Doyle 8 Ton...
2019 Ford F-350 4x4 Ext. Cab Palfinger PSC 3216 4,000LB 2 Ton Mechanics Crane Service Truck (A50323)
2019 Ford F-350...
My-D Hand 10 x 40 Auger (A50515)
My-D Hand 10 x 40...
1999 KENWORTH W900 TANDEM AXLE SLEEPER (A52141)
1999 KENWORTH W900...
