Kubota B8200HST Problems
   / Kubota B8200HST Problems #1
jhall30
Concord,NC
1989 Kubota B8200HST 4WD
ok.... I have a 8200 HST- and was having problems with it missing on cylinder 1 (closest to the radiator) so I did a compression test and got the following results
cyl 1 = 350 dry 365 wet
cyl 2 = 350 dry 360 wet
cyl 3 = 400 dry 415 wet
after that I did a leak down test and all were good so I took the head off and had the head reworked with new springs/valves etc
after I installed the head back on I am still getting nothing on cylinder #1
I can take the exhaust manifold off (muffler)and it's cold as ice out of that #1 exhaust port
now I can give it some throttle and run it up to about 2200rpm's and #1 will try to fire but will not keep firing
I have triple checked the valve lash and all looks good there
have also checked to make sure there was no air in the line on the injector
Also swapped injectors to see if that was the problem...no luck on that one ???????????????
any help or ideas would be greatly appreciated as I am scratching my head now
   / Kubota B8200HST Problems #2
When you say you can pull the exhaust manifold and #1 is cold as ice, is there an excess of raw fuel in the #1 exhaust ? If #1 is not spitting raw fuel then that says injector or injector pump, since you already did an injector swap then the pump is suspect. Of course is there is raw fuel this all goes out the window.
Ray
   / Kubota B8200HST Problems #3
Helloooooo, did ya get ticked off and throw a tarp over it or what?
2017 Chevrolet Malibu (A50324)
2017 Chevrolet...
Danuser Digger F-8 (A52128)
Danuser Digger F-8...
MISC, 3 MAN HUNTING BLIND, FISHING POLES (A51244)
MISC, 3 MAN...
2017 JOHN DEERE 350G EXCAVATOR (A51242)
2017 JOHN DEERE...
Toro Z Master Mower (A50324)
Toro Z Master...
2024 Polaris Ranger 1500 (A50514)
2024 Polaris...
