kubota b8200 hudro trans, no drive
   / kubota b8200 hudro trans, no drive #1
frsnkjhorton
Soubran France
kubota b8200, massey 399,590, 2x35's, fergy 30, ford 3000 pre forse, Sumaco
Hi out there, hope someone can help.....
Have a old Kubota B8200, with a Hydro-stat-trans, it's been laid up a while....drove OK and then suddenly stopped driving, in either forward or reverse, it does however seem to slow the engine a tad at tick-over when u engage either F/R......
there's no oil leaks and there's no mechanical disaster noises, nobody else has been near it.....
the rear diff part of the gearbox is full of clean oil....is this the same oil used in the hydro part of the trans ??
just one other thing, hydraulic oil was found to be getting into the engine oil, but it's now had a new pump fitted and there was a stuck pressure relief valve......!!!!!!!!
are there any simple checks I can do ??????
I have heard that for this type of problem it is not cost effective to repair the trans but replace it with a factory exchange unit, the cost will probably write the tractor off, which would be a shame.......
so any ideas would be most welcome.....
thanks Frank
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2024 JOHN DEERE 461M LOT NUMBER 62 (A53084)
2024 JOHN DEERE...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A52748)
PENDING SELLER...
MACDON C3812 LOT NUMBER 34 (A53084)
MACDON C3812 LOT...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
