Kubota B7100DT 3 point lift
   / Kubota B7100DT 3 point lift #1
westtexus
Hale Center, TX
Kubota L3010
Hi, new user here. I just bought a 1980 Kubota B7100DT, with loader and shredder attachments, 1100 hours. The loader bucket stays in position when raised to any point, with tractor running, the 3 point hitch leaks off and the shredder goes to the ground. I don't believe this is supposed to happen. I have read that adding STP will help this. Is this true, and how much STP to add? Thanks in advance.
   / Kubota B7100DT 3 point lift #3
Most likely you need to replace the o-ring on the piston for the 3pt lift. Search my old posts as I have done this and made a post about it. Pretty easy fix.
Thanks for the replies, guyies. Charlz, the step by step and pics are great, I will most likely fix this on monday. Many thanks!!
Repaired 3 point lift, new seals on piston and cover. Over an hour and only leaked down a bit, with engine shut down. Only thing differant from instructions was that the piston came to the top with arms all the way down. But it is much better now, only 50 cents for o rings.
2020 Toro 6000 Series 60in Zero Turn Commercial Mower (A50322)
2020 Toro 6000...
2013 John Deere 6105D (A50120)
2013 John Deere...
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A51572)
2016 Hino 195h...
2016 Club Car Carryall 1500 4x4 Utility Cart (A50322)
2016 Club Car...
