arislgr
Hi,
My B7100D is grinding the gears when shifting from neutral in any gear. It does not grind them when going from one gear directry to another. I have adjusted the clutch and I believe it works OK.
I believe the idle has increased too much with usage and even through i dont have a tachometer, I want to try adjusting the idle lower.
On the governor I note two possible adjusters, they are both covered with a round plastic cover; one is facing forward and the other faces backwards. Reading through the IT manual, I believe I need to adjust the REAR adjuster.
Is this the right thing to do?
Also, I find it difficult to remove the plastic cover while the governor is mounted on the engine and I am afraid if I remove it by force, it might be damaged.
Am I on the right track? Any help will be greatly appreciated!
Thanks !
Thanks !
