Kubota B7100
   / Kubota B7100 #1
lynndw
Southside Al
Kubota B7100
I have a kubota B7100 4wd hydrostatic that keeps running hot. Its not leaking water but have to keep adding water. Where's it going and why is it running hot?
   / Kubota B7100 #2
My educated guess is that the fins of the the radiator are packed with debris, it overheated and now you have a crack in the cylinder head between the precombustion chamber and the exhaust valve seat.
Brian
   / Kubota B7100 #3
Make sure the oil cooler is clean on the outside. It is just in front of the radiator.
On the radiator also make sure it is clean externally, check that the fan turns and make sure the rad cap is closed and working properly. If the tractor runs too hot steam escapes by the cap and you should hear the whistle on the drainage tube.
Just hope it isn't the head cracked.:mad:
   / Kubota B7100 #4
yep do all the basics like cleaning oil coolers and radiator. also in between them.
Does the upper radiator hose get hot? if not I would put in a new thermostat.
Are you sure your not losing any out of the overflow tube?
if you are losing it out of the overflow then that's good news (in a way). I would put on a new radiator cap.
if not, that could point to it going into the engine internally were it isn't suppose to. How does the oil look? any white smoke (steam) from the exhaust?
2016 CATERPILLAR 336FL EXCAVATOR (A51242)
2016 CATERPILLAR...
1968 CHEVROLET C10 1/2 TON PICKUP TRUCK (A51222)
1968 CHEVROLET C10...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2014 Ford F-550...
2021 John Deere 6130M 4WD Tractor w 620R Loader, Premium Cab, 250 Hours (A51039)
2021 John Deere...
2018 FORD F-150 (A50854)
2018 FORD F-150...
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2011 TROXELL...
