johndeere4440
- Joined
- Nov 15, 2011
- Messages
- 11
hi i just bought a Kubota B7100 diesel tractor. its a gear shift no hydro. but i changed the oil and filter as soon as i got it. when you check the oil before you start it like you should the level is over full by a decent amount. if you start it and run it then shut it off and check the oil level its perfect. im not sure i diesel fuel is going past the rings or if the oil is draining out o the filter because its on sideway and also coming out of the cyclinder walls or whats going on. let me know what you think. thanks
