Kubota B7100 Valve Adjustment Help Needed
   / Kubota B7100 Valve Adjustment Help Needed #1
Hdoilcan
USA
2018 KIOTI CK3510SE CAB, 2475L BACKHOE, 72 BOX BLADE, 72 REAR BLADE, 72 LANDSCAPE RAKE, 1,250 LB 55 GAL DRUM BALLAST, 2018 FERRIS IS 700Z, 26HP 810 VANGUARD ENGINE
I posted this in Parts/ and Repairs but figured I post it here in the Kubota section too.
So I changed out the head gasket on my b7100. Getting everything back together and need to adjust the valve clearance. Hope I’m getting all the terminally right. I understand how to actually adjust them with the feeler gauge. What I’m having a hard time with is understanding where to start. What cylinders are ? ? and ?? The manual says to adjust them in their injection order 1->2->3. Im not really sure I understand what the injection order means? How to know when and what piston is raised ect?
If I’m at the front of the tractor I will number the valve springs in order from 1-2-3-4-5-6. When 1 is compressed so is 6 and then when I turn the crankshaft (?) counter clockwise 4 and 5 will compressor and as I turn it again 2 and 3 will compress. If when 1 and 6 are compressed, what two do I adjust? If 4 and 5 are compressed, then what two do I adjust. And lastly if 2 and 3 are compressed what two do I adjust?
I watched what I could on YouTube but they don’t have a lot on 3 cylinders. Not any that were clear enough for me to understand anyways.
Any help would be great. This is all I have left before I see how I did on changing the head gasket. Almost time to fire her up.
Wooden Dump Barge Wagon (A50515)
Wooden Dump Barge...
Deutz-Allis GVL Poly Corn Head (A50514)
Deutz-Allis GVL...
2014 Ford F-150 XL Ext. Cab Pickup Truck (A50323)
2014 Ford F-150 XL...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2005 Wilson Hopper Bottom Trailer (A50514)
2005 Wilson Hopper...
2019 BOBCAT T770 SKID STEER (A51242)
2019 BOBCAT T770...
