Kubota B7100 Starter Solenoid install
   / Kubota B7100 Starter Solenoid install #1
Notamechanic
Skull Valley, AZ
Kubota B7100
I took my starter solenoid off to clean up the wiring and can't figure how to engage the little hook on the end of it's arm back into the starter housing. It looks like it should grab onto the arm in the back? I put it back together and tried to crank the starter. Everything seems to work fine except once I turn on the starter it just keeps on cranking and I have to disconnect the battery terminal too make it stop? I should have never taken it off. It came off easily. How to put it back together is a mystery.
HELP
   / Kubota B7100 Starter Solenoid install #2
Are you sure you wired it back the way it was? Even on simple stuff I often snap a phone pic before disassembly. Did you do any other wiring at the time you removed the starter?
Jim
   / Kubota B7100 Starter Solenoid install #3
Hold your drive gear forward, this moves the shift arm back making it easier to hook the sol. plunger to the lever, don't forget the return spring, sounds like its just out of place.
Thanks for the advise. I didn't have the hook on to the drive gear. It works like a champ now!
Year: 2002 Make: Western Star Trucks Model: 4900 SA Vehicle Type: Truck Mileage: Plate: Body Type: (A51692)
Year: 2002 Make...
Wolverine Quick Attach 68" Bucket (A50515)
Wolverine Quick...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
1994 Toyota 6000lbs 2 Stage Forklift (A52748)
1994 Toyota...
2017 Nissan Titan Crew Cab Pickup Truck (A50323)
2017 Nissan Titan...
Killbros 250 bu Gravity Wagon (A50515)
Killbros 250 bu...
