Kubota b7100 engine reassembly questions
   / Kubota b7100 engine reassembly questions #1
KubotaVT
Cub Cadet 127, Kubota B7100 HST
Well after a winter cleaning, re-ringing, and honing, it's time for the ol' d750a to go back together. Just a few questions. It'd be convenient if someone knew the answers, although I know they're all probably in the service manual. A bit of laziness on my part I guess.
Are there any cues for the orientation of the piston in the cylinder? I know there's a little "k" on one side of each rod, and I believe those go toward the steering wheel, just confirming.
Torque specs on piston rod bolts?
Any other specific torque specs someone might have access to?
Ring gap measurements?
Thanks for any sort of help you guys can give, I'm currently researching all I can so I won't just sit back and let you guys so all the work =].
Can't wait to get this thing running again!!
2015 MACK GU713 DAYCAB (INOPERABLE) (A50854)
2015 MACK GU713...
2011 KENWORTH T800 SLEEPER (A50854)
2011 KENWORTH T800...
1994 LUFKIN (A50854)
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
WHITE CI-7 DRAW WORKS POWERED BY TWIN (60 SERIES) DETROIT 14.0L ENGINES (A50854)
WHITE CI-7 DRAW...
2021 Kubota RTV X900 4x4 Utility Cart (A50322)
2021 Kubota RTV...
