kubota B7100 4wd
/ kubota B7100 4wd #1
tlr1369
Carneys Point, NJ
kubotab7100hst 4wd
If anyone owns this machine. Please help:eek: I am needing to replace the fanbelt. The only problem is how do you remove it passed the front spline?? Doe's the rad need to be removed and if so what else. I thought this would be a simple job:confused: THis is my second request and I hate to bring it back to the dealer THANKS 'IF ANYONE CAN HELP'
/ kubota B7100 4wd #2
I've answered your other post but danged if I can remember how to change the belt. I do know taking off the rad and oil cooler is no big job. Goes quite quickly as a matter of fact and is very straight forward.:D
Took me two hours to finally realize one had to disconnect a motor mount on a 93 Pontiac Grand Am just to change the belt.:eek::eek::eek:
/ kubota B7100 4wd
Egon, Thanks I just wanted to go in the right direction before I tokk the whole machine apart for a fanbelt!!!:D
/ kubota B7100 4wd #4
When you finish the job please post the steps you needed to go through to complete the fan belt replacment. I have the same setup on my B7100. The drive to the front hydraulic pump stops the fan belt from coming off or going on. I have been very curious as to how complicated that pump drive is to remove when I need to replace my fan belt.
UNUSED RAYTREE RTSG30 - 30" STUMP GRINDER (A62131)
UNUSED RAYTREE...
Kubota Z232 (A60462)
2013 International WorkStar 7400 4x4 Altec Bucket Truck (A61568)
2013 International...
2012 Toyota Camry Sedan (A61569)
2012 Toyota Camry...
John Deere 8310R Tractor (A64047)
John Deere 8310R...
2003 Sterling L8500 Series FEC 3216 8 Ton Tire Boom Truck (A61568)
2003 Sterling...
