Kubota B7001 blowing oil from crankcase vent
   / Kubota B7001 blowing oil from crankcase vent #1
Garden State Mike
Kubota B7001
Greetings- I am the owner of a B7001 Kubota tractor. I am not a mechanic but am trying to learn how to properly maintain this very handy machine.
Had recently developed a problem that I cannot properly diagnose. Shortly after the engine is running a stream of oil starts to blow out of the plastic hose connected to the valve cover vent. A mechanic where I work suggested it may be the ports that are cast into the engine may be clogged and not allowing the oil to drain down from the top of the engine.
Was wondering if anyone has any experience with this issue that can advise me before I start taking things apart.
Thank you.
   / Kubota B7001 blowing oil from crankcase vent #2
That type of a problem could be as suggested but to remove the valve cover would give you the answer to that and taht might be the cheapest repair.
That problem also could be from the rings being shot and excess pressure in the crankcase from it.
2013 Ford Expedition 4x4 SUV (A49461)
2013 Ford...
2016 FREIGHTLINER M2 REFRIGERATED BOX TRUCK (A51222)
2016 FREIGHTLINER...
2015 PETERBILT CLASS 8 CEMENT MIXER TRUCK (A51243)
2015 PETERBILT...
2017 FREIGHTLINER M2 BOX TRUCK (A51222)
2017 FREIGHTLINER...
2007 Reitnouer 40 Ton T/A Flatbed Trailer (A49461)
2007 Reitnouer 40...
2010 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2010 TROXELL...
