Kubota B7000 rotavator
   / Kubota B7000 rotavator #1
mingle
Teyjat
John Dear, Kubota 7000
Can anyone send me a parts diagram or advise on how to remove the rotor on the Kubota rotavator fitted to a Kubota B7000? The chain has broken on the drive to the rotor near the bottom cog, I need to access the bottom to get to the chain and remove any bits that may have fallen down. To access the bottom chain gear I assume I need to remove the rotor on at least one side, I have removed the long bolts on either end which I assume hold the rotors on to a spline but cannot get the rotors off, is there something else holding them on or do I need a special tool?
TANNKO  130BBL VAC TRAILER (A50854)
TANNKO 130BBL VAC...
Harper SB1300 Straw Blower with Hose (A51039)
Harper SB1300...
2007 Mcclain Utility Trailer (A50860)
2007 Mcclain...
2005 Case IH 2062 Flex Draper Header (A50657)
2005 Case IH 2062...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
Peterbilt Neon Sign (A48082)
Peterbilt Neon...
