Kubota B6100e/3 point control lever pulled out of control valve
   / Kubota B6100e/3 point control lever pulled out of control valve #1
Deep Plow
Mattaponi, va
58,8N - 722 IH/case
Servised tranny after water had intered through shifter - flushed and refilled tranny started tractor and 3 point wouldnt work. found lever had slipped out of control valve. Went over motions and remember pulling up on 3 point assembly. WHAT HAPPENED AND HOW DO I FIX IT.
Ok - had time today to disassemble valve. Inside the 3 point control valve the lever has a shift fork that shifts the hydro spool in and out to direct hydro fluid to control up are down on the 3 point. The bolt that secures the fork to the lever was snaped. By over exstinding the 3 point in the up position the leverage snaped the bolt. Looking at several other vaves on various makes of tractors this can be a option to trouble shoot 3 point failure. Replaced the bolt reassembeled and put the little tractor to the plow. NOTE - the Kubotas with manual trannys will allow water to leak into the tranny through the shift boot if cracked are lose (there was 1 1/2 qts of water in this one).
   / Kubota B6100e/3 point control lever pulled out of control valve #3
Adjust the feedback and it well not brake the new bolt.
TKS Leejohn - Just bought the tractor. I snapped the bolt when i picked up on the 3 point. But u r correct the rod with the adjustment locks was bent and out of adjustment. I have been a heavy equipment mech for 47 years and small tractors r a first for me. The tractor doesnt have a alternator and i made a bracket today. Any advise on wiring most of it is cut out and i cant find any specs on hydraulic pressures for this machine.
   / Kubota B6100e/3 point control lever pulled out of control valve #5
It may not have an alternator but it probably does have what Kubota calls a dynamo which charges the battery. They are mounted behind the fan and are easily mistaken for a water pump. A Kubota B6100 does not have a water pump.
What serculates the water ..
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
1275 (A50490)
1275 (A50490)
2016 CATERPILLAR 336FL EXCAVATOR (A51242)
2016 CATERPILLAR...
2018 HINO 268 26FT BOX TRUCK (A51222)
2018 HINO 268 26FT...
NEW HOLLAND TS6.130 TRACTOR (A51406)
NEW HOLLAND...
4 BRIDGESTONE 11R24.5 (A50854)
4 BRIDGESTONE...
