Kubota B6100 clutch will not disengage completely
   / Kubota B6100 clutch will not disengage completely #1
GAS
I have an old B6100 that I bought used 2 years ago. This winter it started to get hard to shift and the clutch would not disengage completely. Then it stuck in forward. I pulled the top off of the gear box and the shift slid on the one shaft was tight. I honed that out and it now shifts fine but the clutch still will not disengage completely. I have adjusted the intermediate rod as far as it will go and have adjusted the end stop to see if this would make a difference. None of this has mad any difference.
Anyone have any ideas?
:eek:
   / Kubota B6100 clutch will not disengage completely #2
Time for a new clutch?
   / Kubota B6100 clutch will not disengage completely #3
I had my old L275 apart over the winter for an engine rebuild. It has a dual-disk clutch....one for the drive, and one for the PTO. The PTO disk was stuck to the pressure plate, actually rusted to it! That explains why it would not release. Maybe you have a similar situation.
After this rebuild, the old girl has earned an indoor spot in the garage! Mother nature can be tough.
   / Kubota B6100 clutch will not disengage completely #4
Or the clutch disc hub splines are rusted to the trans input shaft, preventing the disc from backing away from the flywheel when the pressure plate is released...
   / Kubota B6100 clutch will not disengage completely #5
:eek:
The B6100 and I think all of the B series of that vintage came with a small wood block that was intended to be put in the clutch pivot area to hold the clutch down for storage. It was intended to prevent the clutch disc form rusting to the flywheel. The block was about a 1" cube.
Check in the tool box to see if it there in the back.
Vernon
1264 (A50490)
1264 (A50490)
2015 Kenworth T400 T/A Vactor 2100 Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A50458)
2018 CATERPILLAR...
2015 Volkswagen Passat 1.8T SE Sedan (A50324)
2015 Volkswagen...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
