Kubota b6000
   / Kubota b6000 #1
georgieporgie
The 3 point lift arms on my b6000 lift right up but gradually sink all the way down, even without a load on them. Any advice would be appreciated.
   / Kubota b6000 #2
on my b6100e there is a adjustment under the seat. It is a bolt with a nut on it. Turn it in to slow the decent and turn it out to slow the decent.
   / Kubota b6000 #4
I had a B6000 and I am pretty sure there was no flow adjustment under the seat; so I think you are going to have to have a look at the hydraulic pump. If you have a shop manual, it will help to know the best way to get at the little bugger. I suppose before you do that you should make sure your gear case has enough oil...although that rarely is the problem.
Kenco PH9000 Self-Leveling Pipe Hook - 9,000 LB Capacity, 8FT Max Pipe Length (A51039)
Kenco PH9000...
2005 KENWORTH T800 (A50854)
2005 KENWORTH T800...
2020 KUBOTA RTV...
2015 Chevrolet Express Passenger Bus (A50323)
2015 Chevrolet...
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
2015 DODGE RAM...
