3-Point Hitch KUBOTA B6000 THREE POINT PROBLEM
   / KUBOTA B6000 THREE POINT PROBLEM #1
rwardlow75
Easton Pa.
International 284
CAN ANYONE TELL ME WHY THE THREE POINT ON THE B6000 I JUST PURCHASED RAISES VERY SLOWLY WITH NO POWER? IT FEELS VERY "SPRINGY" WHEN I PUSH DOWN ON IT. IS IT A FLUID LEVEL PROBLEM? I DON'T HAVE A BOOK YET AND DON'T EVEN KNOW WHERE OR HOW TO CHECK THE LEVEL. IS THERE A LEVEL PLUG? ANY HELP WOULD BE GREATLY APPRECIATED. THANKS IN ADVANCE......FORGOT TO MENTION, THIS TRACTOR HAD NOT BEEN RUN FOR THREE YEARS.
YEAH, I KNOW MANY HAVE THAT BUT THIS ONE DOESN'T.:thumbdown:
Thanks for the advice. Wish dealers were open today......lol! Hope someone who has one can help me out here. Thanks again.
   / KUBOTA B6000 THREE POINT PROBLEM #6
It sounds like you have air in the lift cylinders if it is "springy" when you push on it. Yes, it could be low on fluid but I don't know where the dipstick is on that tractor.
Ken
   / KUBOTA B6000 THREE POINT PROBLEM #7
Yours does have a knob that adjusts the speed down, not up.
Maybe your fluid is contaminated, any air should flush out on its own.
Could possibly be very low in fluid.
Most likely the valve could be bad.
If I remember correctly there is no filter on the hydraulic oil, otherwise I'd say that is clogged.
I've got a parts machine with the three point valve if you need a used replacement.
I'd check pressure first though to be sure it is not your pump.
Joel
2018 Ram 3500 Bucket Truck with Duralift DTS29 - 34FT Walk-In Bucket, HEMI Gas, 98K Miles (A51039)
2018 Ram 3500...
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A51222)
2016 VOLVO VNL300...
2023 KAWASAKI MULE (A51243)
2023 KAWASAKI MULE...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A51039)
2016 Ford F550 4x4...
