Oil & Fuel Kubota B6000 Fuel Problem
   / Kubota B6000 Fuel Problem #1
EaTmYtAiLpIpEs
Bronze Member
My kubota b6000 seemed to gel up last saturday. It ran for about 2 minutes then it shut right off. I put it in a warm garage overnight and tried to start it. Nothing just turned over. So I pulled the fuel filter off to see if it was plugged. It isnt. So I bled the system. Nothing. I can force fuel up into the injector pump with an air compressor and air nozel. And it will start right up. If anyone has any ideas. it is a 2 cyl diesel. If anyone knows where I can buy an injector pump rebuild kit or you know someone that has an injector pump they want to sell resonably priced.
   / Kubota B6000 Fuel Problem #2
If you can force fuel to the injector pump and it runs...sounds like either the electric fuel pump (or fuse), or one or both fuel filters. The cartridge filter is between the fuel and injector pumps, and the replaceable element filter is between the tank and fuel pump. Another possibility is a cracked or loose fuel line on the suction side of the fuel pump.
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A49461)
2016 Ford F-150...
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A51039)
2019 Tico Yard...
2015 Kenworth T400 T/A Vactor 2100 Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
2008 Ford F-450 Crew Cab Service Truck (A49461)
2008 Ford F-450...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
