Kubota B600 4wd
   / Kubota B600 4wd #1
Oldie68
Bronze Member
Kubota B6000 and a Ferguson TEA 20
Needing some help with this. 4wd seemed to be working when I got this li'l beast. Not it definitely is not. Pto shaft coming from transmission turning, splines on shafts although worn a bit are good, when I disconnected shaft and or before I could turn each front wheel independently, with shsft remove from front diff I could turn pto shaft in front diff with no noise or restriction/resistance.
Dunno what could have broken but I'm quite sure it's in the front diff. Information offered would be appreciated. Think it's a 73-75 but its a gray tractor.
Thx.
   / Kubota B600 4wd #2
Your description is not clear in the third sentence/statement. If you can post pictures that helps too.
Bottom line, if the front wheel drive is turning from the transfer case to the front drive- great. Rule that out. Second, you say you disconnected this front shaft and the front wheels turn easily - no binding?
If you jack up the front wheels and turn the L or R tire, does the other side go in reverse of that? is there any binding or loose movement in each axle?
   / Kubota B600 4wd
Hi sorry let me attempt to be clearer. I first lifted the front wheels (actually all of them engine running put it it gear in 4wd, only right rear was turning nothing at the front wheels, could turn either front wheel in either direction no resistance and no alternate action from the opposite side. I've shut the machine off still in gear and in 4wd, rotated either front wheel again no resistance and or action from the opposite side. When machine running in gear and 4wd pto shaft from the transmission is turning up to the pinion shaft of the front differential. I removed pto shaft at the U joint at the front differential/pinion shaft I can turn pinion shaft with no resistance, grinding or any sound and still no action at the front wheels. Hope this is clearer.
   / Kubota B600 4wd #4
Clearer - sum and substance the front wheels aren't turning with FWD engaged and you have confirmed a functional transfer of power to the front axle.
- Front Pinon Drive Does Turn so the transfer case is delivering / driving the shaft up to the front axle
- Front Wheels (with 4WD disengaged) do not turn the opposite wheel when one wheel is turned
This likely indicates the center ring and pinion gear inside the center front differential is stripped.
Remove the front wheels and and axle - here is a B6000 part list view From Messicks - yours should be close or similar Kubota B6000 (Hydrostatic Transmission, 4wd) Parts
2003 John Deere 270 Series II Compact Wheel Loader Skid Steer (A50322)
2003 John Deere...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
Year: 2015 Make: Crane Carrier Co. Model: Low Entry (LE2/LD2/LW2/LT2/ST2/SD2) Vehicle Type: Truck (A51692)
Year: 2015 Make...
Agco 8200 Flex Grain Platform (A50514)
Agco 8200 Flex...
Agco S150 Manure Spreader (A50774)
Agco S150 Manure...
2012 Volkswagen Jetta Sedan (A50324)
2012 Volkswagen...
