John can you go into more details on whats happening with your machine?
Not John, but here's the latest
B3350 regeneration information that I have. This information supersedes my 02/2018 post above. Highly abbreviated version.
I can say unequivocally that the regeneration issues with the
B3350 and high end F series mowers using the same engine are NOT fully resolved.
My 3350 is a late SN, 2018, still on the Kubota shipping frame in May of 2018, and not an aged inventory unit. I have been informed by multiple folks including a Kubota regional service representative, that my unit has all of the latest upgrades and fixes. More on this later. Considerable inspection and verification of such was performed prior to delivery last June.
My unit now has about 30 hours on the clock. It has attempted to perform running regeneration operations twice since delivered. Both times it shut down abruptly and would not restart. It is currently at the dealers awaiting authorization from Kubota to attempt further work.
It was trucked to the dealer on May 20. Coincidently, the (new) Kubota regional service representative was at my dealer on the 21st. While there he spent considerable time diagnosing my 3350 and an F series mower with the same engine. The reformer on the F series was replaced and it was sent back to the owner. Time will tell.
No one can find anything wrong with mine. Both times that it failed it stored the common OT code but did not display an error code in the display. After 30+ minutes cool down it will start but my attempts to perform a parked regen failed because the instructions in the owners manual are not correct. Turns out it was trying to perform a (non parked) regen at the time. The instructions in the owners manual are confusing and incorrect in at least one area. Live and learn.
I informed the Kubota representative that I was aware that Kubota is planning to replace the direct injected engine in the
B3350 with a common rail injected engine (knowing that he would not be able to speak to this), and asked if anything more was being done by engineering to address the as yet unresolved issues with the current design. It appears that current status is a wait and see approach to see if issues have been resolved (They aren't.) This experimental approach is problematic as it costs customers money and time. Kubota does not pay transportation for warranty work so I must. I have now paid to have it trucked to the dealer (and back) to have this issue repaired. Paying multiple times to repair the same problem is unacceptable to me.
Current plans for my machine are to send the injector pump and injectors out to verify that there is nothing wrong with either. I believe that this is a waste of time and money but apparently Kubota wants it done. Only after this has been done might they replace the reformer. I believe that replacing the reformer is much more likely to solve the problem with my tractor but remain skeptical.
I was told that the design of the reformer was changed near the SN of my tractor. I was also told that SN records vis a vis engineering changes are not always precise. Moreover, I was told that the SN of the reformer on my tractor was just about impossible to read. Twice I have asked that the reformer be changed on my tractor but Kubota is not yet willing to do this because "It is a $5,000 part." What! Thanks, feds.
Since the 21st, nothing has been done to my tractor because of other work in the shop that was booked earlier. Fair enough.
More to come.
SDT
