Mowing Kubota B3300 mower size
   / Kubota B3300 mower size #1
gregfender
Marion, NC
Kubota L2501 HST
I am thinking of trading my John Deere 1070 for a B3300. For the work I find myself doing anymore, the 1070 is about too big. The problem I have though, is all of the 6' attachments I have. I know I won't be using the 6' box blade or bush hog, but what about my finish mower? It's used just for a regular yard with a couple of steep areas. Anyone have any thoughts on a 6' finish mower on a tractor putting out 25 at the pto?
   / Kubota B3300 mower size #2
A 6' finish mower should be fine. Also a 6' scrape blade, 6' landscape rake, etc will be a good match too. You'll want a 5' bush hog and box blade however.
   / Kubota B3300 mower size #3
I don't think you will have a problem if you keep the grass regularly mowed, which you should do with a finish mower anyway. In fact, before you sell the 6' bush hog, you might want to give it a try behind your new 3300. As long as you are not in too big and thick weeds, I'd bet you would get good results. I use a 6' grader blade behind mine and the main problem is traction but I'm still happy with my 3300.
2020 Western Star Tri Axle Dump (A47384)
2020 Western Star...
UNUSED FUTURE 14' BI-PARTING GATE (DEER SCENE) (A51244)
UNUSED FUTURE 14'...
2017 DITCH WITCH RT30 RIDE-ON TRENCHER (A51242)
2017 DITCH WITCH...
1/2 HP 300-1200 RPM Drive Motors (A47384)
1/2 HP 300-1200...
Magnum 4000 Series Hot Water Pressure Washer (A47384)
Magnum 4000 Series...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
