Kubota B3200 hydraulic flow rate
   / Kubota B3200 hydraulic flow rate #1
maximus188
Kubota M4900 Kubota B3200
Does anyone have any info on the pump flow for the Kubota B3200? Tractor data says it's 6.7 gpm with 9.7 gpm total flow but it also says 3.2 gpm steering flow so something doesn't add up. The pump flow for the newer B2650/3350 is only 5 gpm so I find it hard to believe that the flow would drop on a newer model. Thanks.
   / Kubota B3200 hydraulic flow rate #2
Two pumps running piggy back. One for tractor loader and 3 pt and one for steering.
   / Kubota B3200 hydraulic flow rate #3
B3200 is 9.9 total, 6.7 to the implements. The Bxx50 have a slight reduction in rated rpm which would drop the pump output but not at the level they show so not sure if they are using a smaller pump or not.
The Bxx50 also uses hydrostatic steering as opposed to the power assisted steering on the B3200 so steering pump output could be different which would effect total flow.
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
(2) ROW PLANTER W/ COLE PLANTERS (A51247)
(2) ROW PLANTER W/...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
MARS AIR DOORS TAN BANK (A51248)
MARS AIR DOORS TAN...
UNUSED CFG NT18K EXCAVATOR (A51247)
UNUSED CFG NT18K...
2023 JOHN DEERE 333G LOT IDENTIFIER 242 (A53084)
2023 JOHN DEERE...
