Kubota B2710 vs L2600DT
   / Kubota B2710 vs L2600DT #1
Anonymous Poster
Epic Contributor
I am very interested in the Kubota line and have found 2 similar models that I like. Just wondering the differences between these two lines, besides the transmission. Thanks in advance!
   / Kubota B2710 vs L2600DT #2
Hello DSmith.
Horse power 27. Both B2710 & L2600DT
Engine cylinders. B2710 has 4. L2600DT has 3.
PTO hp.
B2710. 20 @ 2600rpm
L2600DT. 22.5 @ 2800rpm
Weight.
B2710. 1741 lbs
L2600DT. 2359 lbs
Wheel base.
2710. 65.6 inches
L2600DT 61.6 inches.
I hope this information helps,and if you are searching for more specifications just let me and I'll do my best to help.
Take Care.
Thomas..NH
   / Kubota B2710 vs L2600DT #3
D Smith,
Will get my 2710 this afternoon but while researching the purchase I drove both the 2710 (4cyl) and a 2400 (3cyl).
BIG difference in engine vibration. The 2710 (4cyl) ran smooth as silk while the 3cyl had a lot of vibration.
Hope this helps
DaleW The Boy in NY
   / Kubota B2710 vs L2600DT #4
Interesting observation - Normally 3 cylinder and 5 cylinder run smoother than 4 cylinder diesels. /w3tcompact/icons/smile.gif Takes a lot of iron in the flywheel to make a 4 cylinder run smoothly.
   / Kubota B2710 vs L2600DT #5
I bought the L2500 DT. Just seemed like the L series was more for agricultural/heavy duty use, maybe yes maybe no? Anyhow I'm very happy with the tractor but if I was doing it over I think I'd spring for the HST. Also with the DT series you don't get a live PTO which is kind of a pain when brushhogging. Also if you plan on getting a loader you'll really appreciate the HST! My only regret..........
   / Kubota B2710 vs L2600DT #6
Wen, I don't know exactly how they do it, and I've not driven an L2600, but as far as the smoothness of the engine, I couldn't tell any noticeable difference in the 3 cylinder B7100 and TC29 and my 4 cylinder B2710.
Bird
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
WARREN POWER SYSTEMS 100KW GENERATOR (A50854)
WARREN POWER...
**SALE ORDER ANNOUNCEMENT** (A51242)
**SALE ORDER...
2013 MACK CHU613 (A50854)
2013 MACK CHU613...
2013 PETERBILT 367 VACUUM TRUCK (A50854)
2013 PETERBILT 367...
Flatbed Body for Heavy Truck (A50854)
Flatbed Body for...
