Kubota B2710, R4 Tire conversion questions
   / Kubota B2710, R4 Tire conversion questions #1
mismith
Locust, NC
Kubota B2710, and 1937 A John Deere
I have a 2000 year B2710 that came with R3 Turfs. It currently has Firestone field and turf 13.6-16 "on 10" rim" stamped on tire and the best I can tell the rims are 10" Wide. The rear rims themselves have Titan 16W X 10L stamped in them. The fronts are 23 X 8.50-12. I have went to 2 different Kubota dealers and they think I'm crazy for wanting to change them out and say it will be very expensive. They also tell me that I will have to buy new rims as well. Well, I would like to change the fronts to 23 X 8.50-14's anyway. Do I have to change the rear rims? My owners manual says that if my tractor came with R4's then the size would have been 12.4-16 but does not say what rim width they would have been. I don't mind spending the money and I want R4's but I also want to order the correct rims if needed. The dealers don't seem to want to research this info. for me and both have tried to discourage me. I also am having a hard time finding a 12.4-16 R4. Any suggestions, help?
Thanks,
Mike
   / Kubota B2710, R4 Tire conversion questions #2
To my knowledge, you would have to replace tires and rims. It might be a good idea to put an ad on Craighlist looking for someone who has the tires and rims you are looking for and wants what you have.
Also, never mix and match front and rear tires/rims. The tire/rim size is matched to maintain proper gear ratios in the front and rear.
Jim from NH
   / Kubota B2710, R4 Tire conversion questions #3
You can run any size tire and rim....
BUT you must keep front to rear ratio the same as the factory.
You can have AG's on the rear with turfs up front, or any combination... BUT you must consider the ROLLING CIRCUMFERENCE.
While you are researching tires and rims, be sure to make note of that.
All tire manufactures have the information available, just takes a little basic math, you can go over size or under. Keep the ratio (lead/lag) correct.
You are apt to get a much better deal buying tires with rims, check if you have an industrial or agra tire dealer near you, they can figure out what you need and come up with a good price. Also like Jim said, watch for deals on used, they come up all the time... KennyV
BTW, I see this is your first post. Welcome to this 'good' group...
You might go back and update your profile to include your location. Someone readong this may have just what you want AND be very close to your local...
   / Kubota B2710, R4 Tire conversion questions #4
Thanks,
Mike
I know that this is an old thread, but here is some info from my Kubota WSM...,
Tires; B2710, B2910
Farm, (Ag)
Front, 7-12 (4PR) 24 PSI
Rear, 12.4-16 (4PR) 16 PSI
Turf, (R3)
Front, 23X8.50-12 (4PR) 22 PSI
Rear, 13.6-16 (4PR) 14 PSI
Industrial, (R4)
Front, 23X8.50-14 Ind. 35 PSI
Rear, 12.4-16 Ind. (4PR) 20 PSI
Hope this helps.
Regards,
2008 International 4400 Terex Hi-Ranger HRX-55 55ft Material Handling Insulated Forestry Bucket (A48081)
2008 International...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A48081)
2021 Ford F-150...
2015 International DuraStar 4300 26ft. Box Truck (A48081)
2015 International...
UNUSED Clear Corrugated Polycarbonate Roof Panels (A50860)
UNUSED Clear...
2008 Ford Escape XLT SUV (A48082)
2008 Ford Escape...
2008 Honda Civic Sedan (A48082)
2008 Honda Civic...
