Kubota B2650HSD Hydraulic Drain Points
   / Kubota B2650HSD Hydraulic Drain Points #1
HillStreet
Veteran Member
Maine
Kubota B2650HST. Kubota Z125S
I am doing the 50 hour service today. Engine oil is not a problem. I am unsure where the drain points are for the transmission and hydraulic fluids. I do know that there are 2 plugs under the axles, but are there others? Thanks for the help.
   / Kubota B2650HSD Hydraulic Drain Points #2
My similar B3030 has two the two plugs you've found as well a main sump plug and another one near the mid-PTO shaft.
Your operators manual will show the procedure in great detail!
Good Luck!
Thanks number two, I will review the manual again but it just shows the two axle drains and other that says B3050.
   / Kubota B2650HSD Hydraulic Drain Points #4
You might want to review your manual before you drain the hst. I think it requires filters only.
   / Kubota B2650HSD Hydraulic Drain Points #5
Yes, filters only at 50 hours.
Thanks all, I will do filters only.
I did the whole hydraulic system yesterday. When I loosened the HST filter, just a little fluid came out and I put on a new filter. The suction filter was different, all fluid poured out into the bucket when I unscrewed it. I suppose I could have put the new one on right away but was not ready. No problem, all is put back together now.
Oh yeah, back to my original question: there are 2 drain plugs, one at the bottom of each axle (12 mm), and a 17 mm plug near the mid PTO. I did not see any others. Got about 14 quarts out of the system so it drained pretty good.
   / Kubota B2650HSD Hydraulic Drain Points #8
If you block the breather tube, you won't lose much fluid at all -- usually a couple drops. Some folks use a shop vac to provide suction, but I found that blocking the breather is enough. Have the new filter ready to go, pre-filled with some new fluid.
   / Kubota B2650HSD Hydraulic Drain Points #9
Guys. When I had my b2320 I recall driving my tractor on a steep bank sideways. This put the suction filter on the "high side" of the machine. I recall very little oil leaked when I remove the filter
My b2650 is coming up on 50 hrs / hst and suction filter service.
Has anyone tried what I'm taking about with success? Wonder if it works for the b2650 too
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A53426)
2018 FREIGHTLINER...
New Holland Boomer 55 Tractor (A52384)
New Holland Boomer...
1987 FRUEHAUF 150BBL ALUMINUM TANKER TRAILER (A53843)
1987 FRUEHAUF...
Scag STT61V 61in Zero Turn Mower (A51694)
Scag STT61V 61in...
City of Buckhannon Onan 450 Set Stand By Generator (A52384)
City of Buckhannon...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
